If you plan to run workspaces that transform data between the datums NAD27 and NAD83 without explicitly choosing a transformation in a CsmapReprojector transformer, you must decide whether to use datum shift files for Canada or the US.
To apply the setting only to FME processes run by the current user, run one of the following from a command prompt:
Note: You must run the following commands as an Administrator.
To apply the setting to all FME processes run on the machine, run one of the following scripts:
